I'm trying to find a manual with the pin-outs for the control board in this bar. The board id is code-3 t11475 rev-2
That board number doesn't really mean anything, Code 3 didn't keep records on the board, only the serial number which is usually found on the front drivers side corner on the bottom lens. Are you wanting the information on the 16 pin connector?I'm trying to find a manual with the pin-outs for the control board in this bar. The board id is code-3 t11475 rev-2
To expand on my earlier reply; the harness that came out of that 16 pin molex was a standard 16 22ga. wiring harness used in both single colors and multicolored bars for both the 21TR, 21TRPL=(Meant has arrowstik) and 27cc bars Do you at least know what lightbar you have serial number?That board number doesn't really mean anything, Code 3 didn't keep records on the board, only the serial number which is usually found on the front drivers side corner on the bottom lens. Are you wanting the information on the 16 pin connector?
When we were repurposing a bar from the PD to the FD we had to email Code3 for the "as-built" diagram.PS: Code 3 never had a manual or schematic showing the board or what each plug does. The boards were used for many different models of lightbars, Solex, Defender, 2700, 21TR and 21TRPL. All the boards were programmed differently.
That is correct, they would send you the drawing of the bar, all that shows is the modules color(s) and location, takedowns and alley lights but not the wiring colors and what they would be used for.When we were repurposing a bar from the PD to the FD we had to email Code3 for the "as-built" diagram.
