Thanks for the reply Tom! It is very much appreciated! This is why Feniex is the best, you listen and interact with your customers!
I was definitely hinting at a 12 diode extreme single color Apollo head. Even just for sh*ts and giggles, would be fun to see!
The positive switched flasher would prove to be my problem then as the UFM8 is negative switched.
As for the flash patterns, I'm sure it's been suggested, but it would be nice to streamline and have all the same patterns across the all lines. This way you could sync any lighthead with each other. The biggest issue I run into, is wanting to run several different lighthead styles and only able to sync a select few patterns. I was really hoping the new apollo quad patterns listed on the new instructions on you site would sync with T3's quad. Just a thought to pass along.
If your referring to the 2 attack patterns on the T3's, then I've definitely played with them, would love to see those across the line too! Would look badass with a T3/T6/Apollo/Cannon setup!!
Thanks again Tom!!!
